Need some advices.
I would like to achieve this:
Enforcing 2 different sets of security hardening settings to local users vs administrators using BigFix Compliance.
There is no AD in our environment,
Basically, the administrators when login can do almost anything that administrators is granted privilege with. The users when log on should see a locked down Windows, where only the specified application UI is available, no access to taskbar, start menu, Windows explorer, taskbar context menu, empty desktop.
I would like to do this through BigFix. What is the best way to do this?
The standard advice is to ask yourself ‘How would I do this using the command-line?’.
That done, you can then convert that to Bigfix.
Local security policies are likely to be the answer here.
Sounds like Kiosk Mode, that should help with googling. As @trn says, once you know the configuration that is needed, we can help you do it with BigFix.
I always posted queries only after I had exhausted Googling.
So far there isn’t any information on the Internet about how this can be done through command line.
Applying the compliance policy set to the whole computer and all the users on the computer can do this through BigFix, no problem about that.
To apply to specific users or groups, manually how this is being done:
- Create a Group Policy Object Editor MMC, scoped to specifc users or groups. In my requirement, I scoped to non-administrators.
- Use this mmc, set the required settings. Since the mmc scope to users or groups, only the User Configuration container is available.
- When settings are configured through this MMC, Windows creates a registry.pol under a subfolder (named according to the SID of the users or groups) under the %systemroot%\system32\GroupPolicyUsers directory. In the case of non-administrators, the SID is S-1-5-32-545, which is the SID of users group.
- This registry.pol can be copied to other computer to achieve the same results.
Based on this step, we should be able to do this through BigFix, should be something like this:
- Check the users’ membership, if users are non-administrators, then get the SID
- In Windows registry, go to HKU\SID, then set the corresponding registry values
- The relevant check must be done continuously, if users are added to administrators group, then the corresponding registry change must be reset. If new users are added to the users group, the fixlets must then be applied to corresponding keys\values under the new SID.
Can relevant check be done at every logon?
Ah, good find. If you have policies working already, then that’s not exactly the ‘Kiosk Mode’ I described earlier, this sound like more a case for Multiple Local Group Policies (MLGPO).
You won’t need Relevance to constantly evaluate a user’s group membership - instead you need to evaluate that your MLGPO is applied for whichever groups are of concern. I have some content at BigFix.me, check for LGPO or MLGPO. Most MLGPO examples are to apply one policy for Administrators and another for Users, but you can also target any arbitrary group using the group SID.
You can configure the policies using LGPO.exe. For Relevance evaluation, what I’ve done in the past is to build an Action to periodically export the registry.pol to text (also using lgpo.exe), and base the relevance evaluation on the text file contents.
In short, don’t configure per-user registries, configure per-group Local Group Policy.
A couple of examples
This one has the correct URL for LGPO.exe and an example of applying a policy
https://www.bigfix.me/fixlet/details/24619
This one is older, and used manual caching, but an example of exporting the LGPO to registry keys that can be used for relevance checking
Sorry for asking, I would like to change the downloading from Internet to just upload the lgpo.exe file to the BigFix repository as our environment has no Internet access. Is it just to change the url and the hashes? Can I just do a copy of the file lgpo.exe to the %systemroot%\system32 of target computer so the computer will be able to just execute the lgpo command when needed? Any example actionscript I can refer to?
begin prefetch block
add prefetch item name=LGPO.zip sha1=0c74dac83aed569607aaa6df152206c709eef769 size=815660 url=https://download.microsoft.com/download/8/5/C/85C25433-A1B0-4FFA-9429-7E023E7DA8D8/LGPO.zip sha256=6ffb6416366652993c992280e29faea3507b5b5aa661c33ba1af31f48acea9c4
// Download UnZip utility
add prefetch item name=unzip.exe sha1=e1652b058195db3f5f754b7ab430652ae04a50b8 size=167936 url=http://software.bigfix.com/download/redist/unzip-5.52.exe sha256=8d9b5190aace52a1db1ac73a65ee9999c329157c8e88f61a772433323d6b7a4a
collect prefetch items
end prefetch block
I had done one testing using a simple fixlet based on your input:
end prefetch block
// Add LGPO.zip to the client utility cache
utility __Download\LGPO.zip
// Add unzip.exe to the client utility cache
utility __Download\unzip.exe
waithidden __Download\unzip.exe -o “{pathname of client folder of current site}__Download\LGPO.zip” -d “{pathname of client folder of current site}__Download”
delete __createfile
createfile until EOF_EOF_EOF
; PARSING User:Non-Administrators POLICY
; Source file: c:\windows\system32\grouppolicyusers\S-1-5-32-545\user\registry.pol
Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced
ShowTaskViewButton
DWORD:0
Software\Microsoft\Windows\CurrentVersion\Policies\Associations
BlockFileElevation
DWORD:1
BlockProtocolElevation
DWORD:1
Software\Microsoft\Windows\CurrentVersion\Policies\DataCollection
MicrosoftEdgeDataOptIn
DELETE
Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
NoControlPanel
DWORD:1
NoDesktop
DWORD:1
NoClose
DWORD:1
NoSetTaskbar
DWORD:1
NoTrayContextMenu
DWORD:1
NoWelcomeScreen
DWORD:1
NoSMBalloonTip
DWORD:1
NoCommonGroups
DWORD:1
NoStartMenuMFUprogramsList
DWORD:1
NoWindowsUpdate
DWORD:1
NoNetworkConnections
DWORD:1
NoStartMenuPinnedList
DWORD:1
NoSearchComputerLinkInStartMenu
DWORD:1
NoFind
DWORD:1
HideSCAPower
DWORD:1
HideSCANetwork
DWORD:1
HideSCAHealth
DWORD:1
HideSCAVolume
DWORD:1
NoUserNameInStartMenu
DWORD:1
NoStartMenuSubFolders
DWORD:1
TaskbarNoNotification
DWORD:1
QuickLaunchEnabled
DWORD:0
NoAutoTrayNotify
DWORD:1
Intellimenus
DWORD:1
TaskbarNoThumbnail
DWORD:1
NoInstrumentation
DWORD:1
NoPublishingWizard
DWORD:1
NoWebServices
DWORD:1
NoOnlinePrintsWizard
DWORD:1
NoInternetOpenWith
DWORD:1
DontSetAutoplayCheckbox
DWORD:1
NoAutorun
DWORD:1
NoDriveTypeAutoRun
DWORD:255
RestrictWelcomeCenter
DWORD:1
NoDrives
DWORD:67108863
NoManageMyComputerVerb
DWORD:1
NoFolderOptions
DWORD:1
NoComputersNearMe
DWORD:1
NoViewOnDrive
DWORD:67108863
PreventItemCreationInUsersFilesFolder
DWORD:1
NoNetConnectDisconnect
DWORD:1
NoViewContextMenu
DWORD:1
NoFileMenu
DWORD:1
NoHardwareTab
DWORD:1
NoShellSearchButton
DWORD:1
NoSecurityTab
DWORD:1
NoSharedDocuments
DWORD:1
NoChangeKeyboardNavigationIndicators
DWORD:1
NoChangeAnimation
DWORD:1
NoThumbnailCache
DWORD:1
DisableThumbnailsOnNetworkFolders
DWORD:1
DisableThumbnails
DWORD:1
NoWinKeys
DWORD:1
NoToolbarsOnTaskbar
DWORD:1
NoRecentDocsHistory
DWORD:1
NoSearchCommInStartMenu
DWORD:1
NoSearchFilesInStartMenu
DWORD:1
NoSearchInternetInStartMenu
DWORD:1
NoSearchProgramsInStartMenu
DWORD:1
NoResolveSearch
DWORD:1
NoResolveTrack
DWORD:1
NoTrayItemsDisplay
DWORD:1
TaskbarLockAll
DWORD:1
LockTaskbar
DWORD:1
NoTaskGrouping
DWORD:1
TaskbarNoAddRemoveToolbar
DWORD:1
NoChangeStartMenu
DWORD:1
TaskbarNoRedock
DWORD:1
TaskbarNoDragToolbar
DWORD:1
TaskbarNoResize
DWORD:1
HideClock
DWORD:1
ClearRecentDocsOnExit
DWORD:1
ClearRecentProgForNewUserInStartMenu
DWORD:1
ForceStartMenuLogOff
DWORD:1
DisablePersonalDirChange
DWORD:1
NoDesktopCleanupWizard
DWORD:1
NoInternetIcon
DWORD:1
NoNetHood
DWORD:1
NoPropertiesMyComputer
DWORD:1
NoPropertiesMyDocuments
DWORD:1
NoRecentDocsNetHood
DWORD:1
NoPropertiesRecycleBin
DWORD:1
NoSaveSettings
DWORD:1
NoCloseDragDropBands
DWORD:1
NoMovingBands
DWORD:1
NoActiveDesktop
DWORD:1
NoStartMenuMorePrograms
DWORD:1
NoSimpleStartMenu
DWORD:1
StartMenuLogOff
DELETE
Software\Microsoft\Windows\CurrentVersion\Policies\Explorer\WAU
Disabled
DWORD:1
Software\Microsoft\Windows\CurrentVersion\Policies\MobilityCenter
NoMobilityCenter
DWORD:1
Software\Microsoft\Windows\CurrentVersion\Policies\Network
NoEntireNetwork
DWORD:1
Software\Microsoft\Windows\CurrentVersion\Policies\NonEnum
{20D04FE0-3AEA-1069-A2D8-08002B30309D}
DWORD:1
{450D8FBA-AD25-11D0-98A8-0800361B1103}
DWORD:1
{645FF040-5081-101B-9F08-00AA002F954E}
DWORD:1
Software\Microsoft\Windows\CurrentVersion\Policies\System
DisableRegistryTools
DWORD:2
DisableTaskMgr
DWORD:1
DisableLockWorkstation
DWORD:1
Software\Microsoft\Windows\CurrentVersion\Policies\Windows\Sidebar
TurnOffSidebar
DWORD:1
TurnOffUserInstalledGadgets
DWORD:1
TurnOffUnsignedGadgets
DWORD:1
Software\Microsoft\Windows\CurrentVersion\Search
SearchboxTaskbarMode
DWORD:0
Software\Policies\Microsoft\Assistance\Client\1.0
NoOnlineAssist
DWORD:1
NoExplicitFeedback
DWORD:1
NoImplicitFeedback
DWORD:1
Software\Policies\Microsoft\InternetManagement
RestrictCommunication
DWORD:1
Software\Policies\Microsoft\Messenger\Client
CEIP
DWORD:2
PreventRun
DWORD:1
PreventAutoRun
DWORD:1
Software\Policies\Microsoft\PassportForWork
Enabled
DWORD:0
DisablePostLogonProvisioning
DWORD:0
Software\Policies\Microsoft\Windows\AppCompat
DisablePCA
DWORD:1
Software\Policies\Microsoft\Windows\CredUI
DisablePasswordReveal
DWORD:1
Software\Policies\Microsoft\Windows\CurrentVersion\PushNotifications
NoTileApplicationNotification
DWORD:1
NoToastApplicationNotificationOnLockScreen
DWORD:1
DWORD:1
DisallowNotificationMirroring
DWORD:1
Software\Policies\Microsoft\Windows\DataCollection
AllowTelemetry
DELETE
Software\Policies\Microsoft\Windows\Digital Locker
DoNotRunDigitalLocker
DWORD:1
Software\Policies\Microsoft\Windows\EdgeUI
AllowEdgeSwipe
DWORD:0
DisableHelpSticker
DWORD:1
DisableRecentApps
DWORD:1
ShowCommandPromptOnWinX
DWORD:1
DisableCharms
DWORD:1
TurnOffBackstack
DWORD:1
DisableMFUTracking
DWORD:1
Software\Policies\Microsoft\Windows\Explorer
HideRecentlyAddedApps
DWORD:1
DisableNotificationCenter
DWORD:1
TaskbarNoPinnedList
DWORD:1
NoSearchEverywhereLinkInStartMenu
DWORD:1
HidePeopleBar
DWORD:1
ShowWindowsStoreAppsOnTaskbar
DWORD:2
ShowRunAsDifferentUserInStart
DWORD:0
NoSystraySystemPromotion
DWORD:1
NoBalloonFeatureAdvertisements
DWORD:1
NoUseStoreOpenWith
DWORD:1
NoAutoplayfornonVolume
DWORD:1
TryHarderPinnedOpenSearch
DWORD:0
OpenSearch0
DELETE
OpenSearchLabel0
DELETE
OpenSearch1
DELETE
OpenSearchLabel1
DELETE
OpenSearch2
DELETE
OpenSearchLabel2
DELETE
OpenSearch3
DELETE
OpenSearchLabel3
DELETE
OpenSearch4
DELETE
OpenSearchLabel4
DELETE
NoSearchInternetTryHarderButton
DWORD:1
DisableSearchBoxSuggestions
DWORD:1
DisableThumbsDBOnNetworkFolders
DWORD:1
HideContentViewModeSnippets
DWORD:1
DisableIndexedLibraryExperience
DWORD:1
AddSearchInternetLinkInStartMenu
DWORD:0
DisableContextMenusInStart
DWORD:1
EnableLegacyBalloonNotifications
DWORD:1
NoPinningToDestinations
DWORD:1
NoPinningToTaskbar
DWORD:1
NoPinningStoreToTaskbar
DWORD:1
TaskbarNoMultimon
DWORD:1
NoRemoteDestinations
DWORD:1
NoUninstallFromStart
DWORD:1
ClearTilesOnExit
DWORD:1
NoWindowMinimizingShortcuts
DWORD:1
LockedStartLayout
DWORD:1
StartLayoutFile
EXSZ:C:\Windows\System32\GroupPolicyUsers\S-1-5-32-545\User\StartLayout.xml
Software\Policies\Microsoft\Windows\HandwritingErrorReports
PreventHandwritingErrorReports
DWORD:1
Software\Policies\Microsoft\Windows\Installer
DisableMedia
DWORD:1
AlwaysInstallElevated
DWORD:1
Software\Policies\Microsoft\Windows\RemovableStorageDevices
Deny_All
DWORD:1
Software\Policies\Microsoft\Windows\Settings
AllowConfigureTaskbarCalendar
DWORD:0
DELETE
Software\Policies\Microsoft\Windows\System
DisableCMD
DWORD:2
Software\Policies\Microsoft\Windows\TabletPC
PreventHandwritingDataSharing
DWORD:1
Software\Policies\Microsoft\Windows\Windows Error Reporting
Disabled
DWORD:1
Software\Policies\Microsoft\Windows NT\CurrentVersion\Software Protection Platform
NoGenTicket
DWORD:1
AllowWindowsEntitlementReactivation
DWORD:1
Software\Policies\Microsoft\Windows NT\Printers
DisableHTTPPrinting
DWORD:1
DisableWebPnPDownload
DWORD:1
Software\Policies\Microsoft\WindowsMovieMaker
WebHelp
DWORD:1
CodecDownload
DWORD:1
WebPublish
DWORD:1
; PARSING COMPLETED.
EOF_EOF_EOF
delete regpol.txt
move __createfile regpol.txt
waithidden __Download\LGPO.exe /t regpol.txt
continue if {exit code of action = 0}
It returns Failed.
The Action execution detail:
The status after came back as failed, the action steps recorded as follows:
Completed // To use this template, update or remove the following blocks and replace the Relevance
Completed // Enter your action script here
Completed begin prefetch block
Completed add prefetch item name=LGPO.zip sha1=0c74dac83aed569607aaa6df152206c709eef769 size=815660 url=https://download.microsoft.com/download/8/5/C/85C25433-A1B0-4FFA-9429-7E023E7DA8D8/LGPO.zip sha256=6ffb6416366652993c992280e29faea3507b5b5aa661c33ba1af31f48acea9c4
Completed // Download UnZip utility
Completed add prefetch item name=unzip.exe sha1=e1652b058195db3f5f754b7ab430652ae04a50b8 size=167936 url=http://software.bigfix.com/download/redist/unzip-5.52.exe sha256=8d9b5190aace52a1db1ac73a65ee9999c329157c8e88f61a772433323d6b7a4a
Completed collect prefetch items
Completed end prefetch block
Completed // Add LGPO.zip to the client utility cache
Completed utility __Download\LGPO.zip
Completed // Add unzip.exe to the client utility cache
Completed utility __Download\unzip.exe
Completed waithidden __Download\unzip.exe -o “{pathname of client folder of current site}__Download\LGPO.zip” -d "{pathname of client folder of current site}__Download"
Completed action uses wow64 redirection false
Completed delete __createfile
Completed createfile until EOF_EOF_EOF
Completed ; ----------------------------------------------------------------------
Completed ; PARSING User:Non-Administrators POLICY
Completed ; Source file: c:\windows\system32\grouppolicyusers\S-1-5-32-545\user\registry.pol
Completed
Completed User:Non-Administrators
Completed Software\Microsoft\Windows\CurrentVersion\Explorer\Advanced
Completed ShowTaskViewButton
Completed DWORD:0
Completed
Completed Software\Microsoft\Windows\CurrentVersion\Policies\Associations
Completed BlockFileElevation
Completed DWORD:1
Completed
Completed BlockProtocolElevation
Completed DWORD:1
Completed
Completed Software\Microsoft\Windows\CurrentVersion\Policies\DataCollection
Completed MicrosoftEdgeDataOptIn
Completed DELETE
Completed
Completed Software\Microsoft\Windows\CurrentVersion\Policies\Explorer
Completed NoControlPanel
Completed DWORD:1
Completed
Completed NoDesktop
Completed DWORD:1
Completed
Completed NoClose
Completed DWORD:1
Completed
Completed NoSetTaskbar
Completed DWORD:1
Completed
Completed NoTrayContextMenu
Completed DWORD:1
Completed
Completed NoWelcomeScreen
Completed DWORD:1
Completed
Completed NoSMBalloonTip
Completed DWORD:1
Completed
Completed NoCommonGroups
Completed DWORD:1
Completed
Completed NoStartMenuMFUprogramsList
Completed DWORD:1
Completed
Completed NoWindowsUpdate
Completed DWORD:1
Completed
Completed NoNetworkConnections
Completed DWORD:1
Completed
Completed NoStartMenuPinnedList
Completed DWORD:1
Completed
Completed NoSearchComputerLinkInStartMenu
Completed DWORD:1
Completed
Completed NoFind
Completed DWORD:1
Completed
Completed HideSCAPower
Completed DWORD:1
Completed
Completed HideSCANetwork
Completed DWORD:1
Completed
Completed HideSCAHealth
Completed DWORD:1
Completed
Completed HideSCAVolume
Completed DWORD:1
Completed
Completed NoUserNameInStartMenu
Completed DWORD:1
Completed
Completed NoStartMenuSubFolders
Completed DWORD:1
Completed
Completed TaskbarNoNotification
Completed DWORD:1
Completed
Completed QuickLaunchEnabled
Completed DWORD:0
Completed
Completed NoAutoTrayNotify
Completed DWORD:1
Completed
Completed Intellimenus
Completed DWORD:1
Completed
Completed TaskbarNoThumbnail
Completed DWORD:1
Completed
Completed NoInstrumentation
Completed DWORD:1
Completed
Completed NoPublishingWizard
Completed DWORD:1
Completed
Completed NoWebServices
Completed DWORD:1
Completed
Completed NoOnlinePrintsWizard
Completed DWORD:1
Completed
Completed NoInternetOpenWith
Completed DWORD:1
Completed
Completed DontSetAutoplayCheckbox
Completed DWORD:1
Completed
Completed NoAutorun
Completed DWORD:1
Completed
Completed NoDriveTypeAutoRun
Completed DWORD:255
Completed
Completed RestrictWelcomeCenter
Completed DWORD:1
Completed
Completed NoDrives
Completed DWORD:67108863
Completed
Completed NoManageMyComputerVerb
Completed DWORD:1
Completed
Completed NoFolderOptions
Completed DWORD:1
Completed
Completed NoComputersNearMe
Completed DWORD:1
Completed
Completed NoViewOnDrive
Completed
Completed PreventItemCreationInUsersFilesFolder
Completed DWORD:1
Completed
Completed NoNetConnectDisconnect
Completed DWORD:1
Completed
Completed NoViewContextMenu
Completed DWORD:1
Completed
Completed NoFileMenu
Completed DWORD:1
Completed
Completed NoHardwareTab
Completed DWORD:1
Completed
Completed NoShellSearchButton
Completed DWORD:1
Completed
Completed NoSecurityTab
Completed DWORD:1
Completed
Completed NoSharedDocuments
Completed DWORD:1
Completed
Completed NoChangeKeyboardNavigationIndicators
Completed DWORD:1
Completed
Completed NoChangeAnimation
Completed DWORD:1
Completed
Completed NoThumbnailCache
Completed DWORD:1
Completed
Completed DisableThumbnailsOnNetworkFolders
Completed DWORD:1
Completed
Completed DWORD:1
Completed
Completed NoWinKeys
Completed DWORD:1
Completed
Completed NoToolbarsOnTaskbar
Completed DWORD:1
Completed
Completed NoRecentDocsHistory
Completed DWORD:1
Completed
Completed NoSearchCommInStartMenu
Completed DWORD:1
Completed
Completed NoSearchFilesInStartMenu
Completed DWORD:1
Completed
Completed NoSearchInternetInStartMenu
Completed DWORD:1
Completed
Completed NoSearchProgramsInStartMenu
Completed DWORD:1
Completed
Completed NoResolveSearch
Completed DWORD:1
Completed
Completed NoResolveTrack
Completed DWORD:1
Completed
Completed NoTrayItemsDisplay
Completed DWORD:1
Completed
Completed TaskbarLockAll
Completed DWORD:1
Completed
Completed LockTaskbar
Completed DWORD:1
Completed
Completed NoTaskGrouping
Completed DWORD:1
Completed
Completed TaskbarNoAddRemoveToolbar
Completed DWORD:1
Completed
Completed NoChangeStartMenu
Completed DWORD:1
Completed
Completed TaskbarNoRedock
Completed DWORD:1
Completed
Completed TaskbarNoDragToolbar
Completed DWORD:1
Completed
Completed TaskbarNoResize
Completed DWORD:1
Completed
Completed HideClock
Completed DWORD:1
Completed
Completed ClearRecentDocsOnExit
Completed DWORD:1
Completed
Completed ClearRecentProgForNewUserInStartMenu
Completed DWORD:1
Completed
Completed ForceStartMenuLogOff
Completed DWORD:1
Completed
Completed DisablePersonalDirChange
Completed DWORD:1
Completed
Completed NoDesktopCleanupWizard
Completed DWORD:1
Completed
Completed NoInternetIcon
Completed DWORD:1
Completed
Completed NoNetHood
Completed DWORD:1
Completed
Completed NoPropertiesMyComputer
Completed DWORD:1
Completed
Completed NoPropertiesMyDocuments
Completed DWORD:1
Completed
Completed NoRecentDocsNetHood
Completed DWORD:1
Completed
Completed NoPropertiesRecycleBin
Completed DWORD:1
Completed
Completed NoSaveSettings
Completed DWORD:1
Completed
Completed NoCloseDragDropBands
Completed DWORD:1
Completed
Completed NoMovingBands
Completed DWORD:1
Completed
Completed NoActiveDesktop
Completed DWORD:1
Completed
Completed NoStartMenuMorePrograms
Completed DWORD:1
Completed
Completed NoSimpleStartMenu
Completed DWORD:1
Completed
Completed StartMenuLogOff
Completed DELETE
Completed
Completed Software\Microsoft\Windows\CurrentVersion\Policies\Explorer\WAU
Completed Disabled
Completed DWORD:1
Completed
Completed Software\Microsoft\Windows\CurrentVersion\Policies\MobilityCenter
Completed NoMobilityCenter
Completed DWORD:1
Completed
Completed Software\Microsoft\Windows\CurrentVersion\Policies\Network
Completed NoEntireNetwork
Completed DWORD:1
Completed
Completed Software\Microsoft\Windows\CurrentVersion\Policies\NonEnum
Failed {20D04FE0-3AEA-1069-A2D8-08002B30309D}
DWORD:1
DWORD:1
DWORD:1
DWORD:2
DisableTaskMgr
DWORD:1
DWORD:1
TurnOffSidebar
DWORD:1
DWORD:1
DWORD:1
DWORD:0
NoOnlineAssist
DWORD:1
NoExplicitFeedback
DWORD:1
NoImplicitFeedback
DWORD:1
DWORD:1
CEIP
DWORD:2
PreventRun
DWORD:1
PreventAutoRun
DWORD:1
Enabled
DWORD:0
DWORD:0
DisablePCA
DWORD:1
DWORD:1
DWORD:1
DWORD:1
DWORD:1
DWORD:1
AllowTelemetry
DELETE
DWORD:1
AllowEdgeSwipe
DWORD:0
DisableHelpSticker
DWORD:1
DisableRecentApps
DWORD:1
DWORD:1
DisableCharms
DWORD:1
TurnOffBackstack
DWORD:1
DisableMFUTracking
DWORD:1
DWORD:1
DWORD:1
TaskbarNoPinnedList
DWORD:1
DWORD:1
HidePeopleBar
DWORD:1
DWORD:2
DWORD:0
DWORD:1
DWORD:1
NoUseStoreOpenWith
DWORD:1
DWORD:1
DWORD:0
OpenSearch0
DELETE
OpenSearchLabel0
DELETE
OpenSearch1
DELETE
OpenSearchLabel1
DELETE
OpenSearch2
DELETE
OpenSearchLabel2
DELETE
OpenSearch3
DELETE
OpenSearchLabel3
DELETE
OpenSearch4
DELETE
OpenSearchLabel4
DELETE
DWORD:1
DWORD:1
DWORD:1
DWORD:1
DWORD:1
DWORD:0
DWORD:1
DWORD:1
DWORD:1
NoPinningToTaskbar
DWORD:1
DWORD:1
TaskbarNoMultimon
DWORD:1
DWORD:1
DWORD:1
ClearTilesOnExit
DWORD:1
DWORD:1
LockedStartLayout
DWORD:1
StartLayoutFile
DWORD:1
DisableMedia
DWORD:1
DWORD:1
Deny_All
DWORD:1
DWORD:0
DELETE
DisableCMD
DWORD:2
DWORD:1
Disabled
DWORD:1
NoGenTicket
DWORD:1
DWORD:1
DisableHTTPPrinting
DWORD:1
DWORD:1
WebHelp
DWORD:1
CodecDownload
DWORD:1
WebPublish
DWORD:1
EOF_EOF_EOF
delete regpol.txt
Checking at the client side, nothing was done. Anyone can figure out what was wrong? Where can I check what went wrong?
Sorry, still scrolling my phone, catch up to you in a bit…
Ok here I am …
Check the ‘Failed’ line. There’s a GUID in your text that is being evaluated as a Relevance Substitution . Change the { to {{
I’m also not sure that’s the right format for MLGPO. The LGPO download has a PDF in it with instructions, check that to be sure. I thought all the text should specify USER, and then in the LGPO.command line we specify which “User” it applies too, but I’m.not certain on that point.
Thank you.
I added the ‘{’ and ‘}’, this allow the execution of all the lines completed but it still show status of failed.
I checked at the target computer, the non-admin hardening is done. So, it works, though need to find out why status is ‘failed’.
For LGPO usage, we have to first parse registry.pol to .txt using LGPO /ua, then when apply the non-admin .txt to the target computer, run the GLPO.exe /t.
The setting contains one ‘Start Layout’ which requires an .xml file, so this file need to be copied to the location specified in the ‘start layout’ setting. any example actionscript for copying a file? I want it copied to %systemroot%\system32\grouppolicyusers\user.
A drawback of this method is that it only takes care of the settings in ‘Administrative Template’, the settings under ‘Windows Settings’ in GPO aren’t captured. In my requirement, I need a logon script, this isn’t incorporated, so the resultant GPO doesn’t have this setting.
I think the easiest way to do hardening when computers are not joined to domain, is simply just set up one machine, harden the necessary, then copy all the files under %systemroot%\system32\grouppolicy and %systemroot%\system32\grouppolicyusers to the target computer, then run a secedit or lgpo command to apply the .inf. The .inf can be obtained from running lgpo /b, then using lgpo /s to apply at the target, or using scedit export, then import. Or, a fixlet can be created to compose the .inf and run lgpo /s.
Then for Windows Firewall, have to export firewall rulse to .wfw and import into target, via netsh.
So far I find that if I use fixlets available in BigFix to harden the settings under Administrative Templates, they are able to set the registry values correctly but the settings value aren’t reflected in GPO, that is, in gpedit.msc, all the values in Administrative Templates remains as ‘Not Configured’. This may be correct behaviour of Windows but this doesn’t look good for auditing. However, if I simply copy the respective registry.pol files into the grouppolicy\user and grouppolicy\machine, then they show up correctly in gpedit.msc.
Maybe there is other better ways to accomplish this.
