Hi
I’m having a encoding problem when I extract informations using Presentation Debugger or the API.
I have created a task which make a powershell call creating a file, which holds information regarding active directory users. This file is created using UTF8 encoding.
This file is then uploaded to BigFix using an Analysis, again using UTF8 encoding.
The creation of the file doesn’t give any errors, neither does the upload and it looks like everything is there, when I look in the console.
But when I try to read the property using the Presentation Debugger it gives me “Error: WindowsCharacterSetResult: Error 1113 (No mapping for the Unicode character exists in the target multi-byte code page.) in TranscodeU8ToU16.” and if I read it using the API , the result is “The expression could not be evaluated: 19InvalidTextEncoding”.
Anyone who has had this kind of “challenges” and ideas how to solve this.
Thanks in advance.
