Enabling standby on clients
(imported topic written by cwstad91)
Is it possible to deploy one action to the clients which enables stanby for all users, and clients wherby there are no users logged on.
thanks
Sure… Use the “Force Standby” Fixlet and in the Take Action Dialog, pick the option to only apply if no user is logged in…
(imported comment written by cwstad91)
Thanks Ben, is there a way that i can add some parameters to this so that i the clients go into standby after a certain period similar to the power profile wizard?
You can just use the power profile wizard for that…
