(imported topic written by DotA)
I’m trying to combine two working relevancies into one using embedded substitution. Basically retrieving a GUID string from the registry to look up the existance of another reg key based on the retrieved GUID.
The two separate relevancies are:
1)value “netcfginstanceID” of key “HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0016” of registry as string
This returns value of {3CFA47EC-2DC6-46E4-9CE9-620C0FF8BF4F}
2)exists value “MTU” of key “HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces{3CFA47EC-2DC6-46E4-9CE9-620C0FF8BF4F}” of registry
This returns TRUE (or FALSE)
I’d like to insert relevancy 1) into relevancy 2) in place of the {GUID} to detect the if the MTU setting exists. This is what I have so far:
exists value “MTU” of key ((“HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\Tcpip\Parameters\Interfaces\value netcfginstanceID of key HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class{4D36E972-E325-11CE-BFC1-08002bE10318}\0016” of registry) as string) of registry
Currently it returning “Singular expression refers to nonexistent object.”
Not sure if we are attempting to ask BigFix to do something it can’t, but any help would be appreciated.
Thank you in advance!
