q: (concatenation of substrings separated by “%0a” of (if (exists first “000000fc00” of it) then hexadecimal string (first 24 of following texts of first “000000fc00” of it ) else “n/a”), concatenation of substrings separated by “%0a” of (if (exists first “000000ff00” of it) then hexadecimal string (first 24 of following texts of first “000000ff00” of it ) else “n/a”), (hexadecimal integer (first 2 of following text of position 32 of it )/4) as string & “/” & (1990+(hexadecimal integer (first 2 of following text of position 34 of it ))) as string) of (values “EDID” of keys ((“HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum” & it & “\Device Parameters”) of (string values of selects “PNPDeviceID from Win32_DesktopMonitor” of wmi) ) of registry as string)
A: DELL E170S , M875N96J084S, 6/2009
Is there any way that it will only provide only 1 result.
Thanks for reply. I have added “unique values of” to the front of the expression but still the result is same.
Appologies if i have mistaken somewhere in writing expression, i m new to bigfix and still learning.
Kindly suggest.
(unique values of concatenation of substrings separated by “%0a” of (if (exists first “000000fc00” of it) then hexadecimal string (first 24 of following texts of first “000000fc00” of it ) else “n/a”), concatenation of substrings separated by “%0a” of (if (exists first “000000ff00” of it) then hexadecimal string (first 24 of following texts of first “000000ff00” of it ) else “n/a”), (hexadecimal integer (first 2 of following text of position 32 of it )/4) as string & “/” & (1990+(hexadecimal integer (first 2 of following text of position 34 of it ))) as string) of (values “EDID” of keys ((“HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum” & it & “\Device Parameters”) of (string values of selects “PNPDeviceID from Win32_DesktopMonitor” of wmi) ) of registry as string)
unique values of ((concatenation of substrings separated by “%0a” of (if (exists first “000000fc00” of it) then hexadecimal string (first 24 of following texts of first “000000fc00” of it ) else “n/a”), concatenation of substrings separated by “%0a” of (if (exists first “000000ff00” of it) then hexadecimal string (first 24 of following texts of first “000000ff00” of it ) else “n/a”), (hexadecimal integer (first 2 of following text of position 32 of it )/4) as string & “/” & (1990+(hexadecimal integer (first 2 of following text of position 34 of it ))) as string) of (values “EDID” of keys ((“HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum” & it & “\Device Parameters”) of (string values of selects “PNPDeviceID from Win32_DesktopMonitor” of wmi) ) of registry as string) as string)
I’ve got this property in my BigFix environment and servers report back as an error of “Singular expression refers to non existant object”. I know this is because they likely don’t have a monitor attached. Is there a way to make this statement put a nice elegant N/A if no data is returned? The servers in question are Server 2008 and 2003.
Hmm… It might be that you have a monitor that doesn’t have a date… Try:
q: unique values of (((concatenation of substrings separated by “%0a” of hexadecimal string (first 24 of following texts of first “000000fc00” of it ) ) | “n/a”, (concatenation of substrings separated by “%0a” of (hexadecimal string (first 24 of following texts of first “000000ff00” of it ))) | “n/a”, ((hexadecimal integer (first 2 of following text of position 32 of it )/4) as string & “/” & (1990+(hexadecimal integer (first 2 of following text of position 34 of it ))) as string) | “n/a”) of (values “EDID” of keys ((“HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Enum” & it & “\Device Parameters”) of (string values of selects “PNPDeviceID from Win32_DesktopMonitor” of wmi) ) of registry as string) as string)
