Does BigFix 9.1 work with MS SQL2016
I was wondering if BF9.1 works with SQL2016. Can anyone provide an answer?
Thanks.
Hello,
By “works with” what do you mean? using it as BigFix server DB? Or able to patch, etc… ?
If you are trying to use SQL2016 as the DB for BigFix then you need at least 9.5.3
See http://www-01.ibm.com/support/docview.wss?uid=swg21972180
Yes, SQL2016 for the DB.
Thank you so much.
