Distribution for relay
Hello!
Please advise what operating system to use to bring up the relay.
The relays already in use are on CentOS 7, but it is too outdated. CentOS 8 support ends in 2024 and I wouldn’t want to consider it either. Was looking at Oracle Linux, but it’s kind of unsupported.
What do you recommend to use, preferably from rpm-based distributions? Windows is not suggested.
Check https://support.hcltechsw.com/csm?id=kb_article&sysparm_article=KB0104120
Be sure to look at the ‘Relay’ column for whether Relay is supported on the OS
