(imported topic written by SarahGalvan)
I need to add the same analysis to several IBM TEM installations. What are the options available to avoid a bunch of copying and pasting?
Thank you!
Thank you!
Export to a .BES file and import should work.
Martin Carnegie
Gulf Breeze Software Partners
(imported comment written by SarahGalvan)
Thank you for the quick response! Is there a way to setup custom gather feeds like we see for IBM TEM fixlet sites? That way further changes can be pulled automatically?
Another option is using IEM v9 and take advantage of the REST API. I’m using it to build a sync “thing” similar to what you’re referring too and the REST API is working great.
I’ve been documenting my work, have a sample c# app and class libraries at http://bigfix.me/restapi
