The “Java Runtime Environment - Disable Java Update (x64)” fixlet does not show relevant for 64bit Windows 7 machines that have the 32bit version of Java loaded on them in our environment. The part of the relevance that is evaluating to false is:
exists key whose (((it contains "java" OR it contains "j2se") AND (it contains "runtime environment" OR it contains "update")) of (value "DisplayName" of it as string as lowercase) AND value "DisplayVersion" of it as string as version >= "1.4.2") of key "HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall" of x64 registry
If I change the last part to be “of registry” instead of “of x64 registry” then it evaluates to true. The 32bit version of the fixlet only runs on 32bit Windows and the 64bit version of the fixlet doesn’t address 32bit Java (apparently). Is it possible for this to get addressed?
In the meantime, I guess I could create a copy and change the relevance to that above and the action language to be regset instead of regset64.
For me, to make it work, I needed to change the following relevance (7) and (8) and remove x64 registry reference:
Relevance 7
NOT exists key “HKLM\SOFTWARE\JavaSoft\Java Update\Policy” of registry
OR
NOT exists value “EnableAutoUpdateCheck”
whose
it = 0
of it
OR
NOT exists value “EnableJavaUpdate”
whose
it = 0
of it
of key “HKLM\SOFTWARE\JavaSoft\Java Update\Policy” of registry
NOT exists key “HKLM\SOFTWARE\JavaSoft\Java Update\Policy” of registry OR (NOT exists value “EnableAutoUpdateCheck” whose (it = 0) of it OR NOT exists value “EnableJavaUpdate” whose (it = 0) of it) of key “HKLM\SOFTWARE\JavaSoft\Java Update\Policy” of registry
Relevance 8
exists key
whose
it contains “java”
OR
it contains “j2se”
AND
it contains “runtime environment”
OR
it contains “update”
of
value “DisplayName” of it as string as lowercase
AND
value “DisplayVersion” of it as string as version >= “1.4.2”
of key “HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall” of registry
exists key whose (((it contains “java” OR it contains “j2se”) AND (it contains “runtime environment” OR it contains “update”)) of (value “DisplayName” of it as string as lowercase) AND value “DisplayVersion” of it as string as version >= “1.4.2”) of key “HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall” of registry
