I created a custom checklist for DISA STIG checklist for Windows 2008 R2 DC. One of the fixlets, Source ID: CCE-10673-2 “The required legal notice will be configured to display before console login” has two hard coded values for the legal notice.
There is not a parameter to this fixlet.
How do I go about creating a custom fixlet or setting a parameter so that the fixlet uses my sites legal notice?
If I have to use ‘Edit Fixlet’, what is the character replacement scheme to use? It looks like spaces are \s, periods are escaped. What about apostrophes?
I just got done with tangling with this particular check myself. My research shows that regex can be used a number of different ways but the way that worked for me was using a “.+” for spaces, using “” as an escape, and using “[–]” as a new line/paragraph. Also you will need to break the string up using " & " to concatenate because if your string that you’re searching for can only be so many characters and it will count all of the symbols you’re using in the count so I did it where every two lines got the " & " concatentation. Here is a slice of some of my expression.
