Hi All,
Could anyone please explain what is the difference between _BESClient_Report_MinimumAnalysisInterval and the option in analysis properties “Evaluate Every”.
Hi All,
_BESClient_Report_MinimumAnalysisInterval is a client level setting that will set the most often the client will evaluate all properties regardless of the properties “Evaluate Every” setting. It is the slowest of the two that will be effective.
So basically all properties set to “Every Report” will be effected by the “MinimumAnalysisInterval” as well as any property with an “Evaluate Every” setting that is less than the “MinimumAnalysisInterval”. A property with a much longer evaluation interval… like once every 30 days… will not be affected.
Related: https://github.com/jgstew/bigfix-content/blob/master/dashboards/PropertyEvaluationAudit.ojo
