Yes, but you won’t be able to bare-metal boot from the network.
You can either create Network Boot Media, usually a USB flash drive, that you can use to boot the target computer, supply IP info manually, and download the install image from the OSD server; or create Offline Installation Media, which includes both the boot and the installation image to handle it offline completly
