Hi Team
Windows System How to DHCP disabled and enable from bigfix
- Silent disabling of static ip address setting
- Silent enabling of static ip address setting
Hi Team
You could use a BigFix Action to execute ‘netsh.exe’ commands to accomplish that.
Thanks i have created Script
How we can enable network dhcp trace in bigfix,is there any script/command?
Please share
Please give me the solution
How do you enable network DHCP trace outside of BigFix? I’m not familiar with what you are talking about.
Investigate netsh dhcpclient
But Want to use runtime parameter in action script. this command is not working with put the parameter.also where we can set parameter value in this command??
Can you share your current action script that’s not working?
Why? There aren’t many options for netsh dhcpclient trace. What are you trying to achieve?
Show your current script and the issues found.
