(imported topic written by ErnieF91)
I can successfully determine what servers are running IIS and WWW, but is there a way to report on what actual WWW sites are running under them?
Thanks,
Ernie
Thanks,
Ernie
(imported comment written by JasonO91)
Hey Ernie,
How’s that car of yours? =)
Here’s a vbscript to get the information you want into a csv file. You could pull all of the same information from wmi, and save it to each of your IIS servers via custom property.
This will attempt to create a file for each of your servers with the IIS information.
Be sure to change the 204.204.204.204 to where you want the files to be created.
on error resume next
Dim objnet
set objnet = wscript.createobject(“wscript.network”)
dim strinfo
strinfo = objnet.computername
Dim filesys, testfile
Set filesys = CreateObject(“Scripting.FileSystemObject”)
MachineName = strinfo
IIsObjectPath = “IIS://” & MachineName & “/w3svc”
Set IIsObject = GetObject(IIsObjectPath)
if err.number 0 then
wscript.quit
end if
Set testfile = filesys.CreateTextFile("\204.204.204.204\iis" & strinfo & “.csv”, True)
testfile.write strinfo & “,”
testfile.writeline
testfile.write “Description” & “,” & “IP” & “,” & “Port” & “,” & “HostHeader” & “,”
testfile.writeline
for each obj in IISObject
if (Obj.Class = “IIsWebServer”) then
BindingPath = IIsObjectPath & “/” & Obj.Name
Set IIsObjectIP = GetObject(BindingPath)
ValueList = IISObjectIP.Get(“ServerBindings”)
ValueString = “”
For ValueIndex = 0 To UBound(ValueList)
value = ValueList(ValueIndex)
Values = split(value, “:”)
IP = values(0)
if (IP = “”) then
IP = “(All Unassigned)”
end if
TCP = values(1)
if (TCP = “”) then
TCP = “80”
end if
HostHeader = values(2)
If (HostHeader = “”) then
HostHeader = “None”
end if
testfile.Write IISObjectIP.ServerComment & “,”
testfile.write IP & “,”
testfile.write TCP & “,”
testfile.write HostHeader & “,”
testfile.writeline
Next
set IISObjectIP = Nothing
end if
next
set IISObject = Nothing
set objnet = nothing
If you want, I can take a look at getting the wmi into a custom property.
Jason
Ernie,
Download and install the IIS Resource kit on a web server from:
http://support.microsoft.com/kb/840671
Then you can use the IIS Metabase Explorer to see the values of the metabase.
For example, to pull the Server Comment from the default web server:
values whose (identifier of it as integer = 1015) of key “/LM/W3svc/1” of metabase
We could still use some help iterating through the LM/W3svc to get all of the Web Servers and then information about each
Jason
Hey JasonO,
Did you guys see this post?
http://forum.bigfix.com/viewtopic.php?id=101
Ben,
That’s where I started looking for the metabase explorer. Those queries point to the correct location of the data. I think what Ernie and I are looking for, would be something like this:
Server Comment | Host Header | Port
So that he can see all of the URLs that the machine will respond to.
This is close to what I want, but it returns information seperately. What I’d like to perform is retrieve both properties at the same time.
values whose (identifier of it as integer = 1015 or identifier of it as integer = 1023) of keys of key “LM\w3svc” of metabase as string
I’ve looked at the WinInspectors, and any other documentation I can get my hands on. There just aren’t very many examples to look at when it comes to using the metabase.
Jason
Try this… It will iterate over each key and concatenate the results together for keys that have the two values…
q:(value whose (identifier of it as integer = 1015) of it as string & “-” & value whose (identifier of it as integer = 1023) of it as string) of keys whose (exists value whose (identifier of it as integer = 1015) of it AND exists value whose (identifier of it as integer = 1023) of it )of key “LM\w3svc” of metabase as string
A: Default Web Site-:80:
(imported comment written by JesseR91)
Ben Kus
Ben,
Jason is here working with me and we created a task with the above revelance and it does work. However, this is the ouput when viewed in Web Reports.
Default Web Site-:81:%00;
SharePoint Central Administration-:5000:%00;
STS-:82:%00;
As you can see its returning a %00 at the end of each one. Do you have any idea what the cause of that is?
%00 is a null termination character. You’ll sometimes see registry keys or other strings include these characters. You can strip it out in the property:
q: (if (it contains “%00”) then (preceding text of last “%00” of it) else (it)) of (it as string) of (value whose (identifier of it as integer = 1015) of it as string & “-” & value whose (identifier of it as integer = 1023) of it as string) of keys whose (exists value whose (identifier of it as integer = 1015) of it AND exists value whose (identifier of it as integer = 1023) of it )of key “LM\w3svc” of metabase as string
(imported comment written by ErnieF91)
Thanks a bunch, it works great. I knew if I posted, the answers would be waiting for me when I returned from vacation.
After 38 years the car is still plugging along.
Ernie
