New machines imaged and found setting DeploymentImage stage code of 9999 instead of 0.
anything we can check here to fix,
Regards,
Shaban
Regards,
Shaban
Hi Shahban.
How do you image the new computers (e.g. bare metal deployment, reimage) ? How do you assign this computer setting?
Thanks.
Hi Sergio.
This is new image deploy by bare metal and some machines are having this issue others are fine.
Hi.
Could you please send a screenshot of the bare metal profile with that setting? Is the image being deployed captured or setup?
Thanks.
Its image deployed by captured.
Also I have checked in client log and found DeploymentStage task executed but registry value not created in machine.
I suggest to refer to BigFix support team to have more details about the information to collect to investigate the issue.
Thanks.
