hi
i have an exe file (not msi) with command switches for silent installation, serial number etc.
i need a manual task that will show me which of the computers doesn’t have this program installed, and show it to me so i can install it manually with bigfix, no reapply.
so, the relevance is ok, i’ll handle that. but about the installer.
it’s something like program.exe /d /quiet /key:dfkdkdkddkdkdkdxxxxxxx and so on and so forth
This command uses CreateProcess to launch a command in a hidden window. It hides the window by setting the STARTUPINFO dwFlags to STARTF_USESHOWWINDOW and setting wShowWindow to SW_HIDE. The process that is created may modify that flag to subsequently show the window again.
You can then utilize action parameter query to prompt operators for inputs for the EXE switches that unique values per execution.
I’d look at using the Software Deployment Wizard. It allows you to upload your installer to the BigFix server, and builds a Task to manage downloading and executing the installer. The wizard asks you for the command-line switches that may be needed for a silent installation.
i now see that i have a predefined batch file that launches this exe with it’s switches. so what’s the simplest way to launch this batch on the endpoint?
