system
January 16, 2009, 11:03pm
1
(imported topic written by FITZPAW91)
Hi all
I am trying to deploy an application via the Software Distribution Wizard, but before it runs, I want to run a VBS that is downloaded along with the application that will change one setting in a config file to show current computers name. I can’t get this to work.
Any help would be appreciated.
extract 4.6.5.5120.0.tmp
waithidden wscript /e:vbs replace.vbs Nom_du_Serveur “WE %COMPUTERNAME%” Arcsight_SilentInstallation_Windows2003
wait __Download\ArcSight-4.6.5.5120.0-Connector-Win.exe -i silent -f “C:\Program Files\BigFix Enterprise\BES Client__BESData\CustomSite_LQ_Home_Made__Download\Arcsight_SilentInstallation_Windows2003”
system
January 17, 2009, 12:49am
2
(imported comment written by arnaud91)
Hi Fitzpaw,
You could try to replace “WE %COMPUTERNAME” with “WE {computer name}” in the wscript command line.
Arnaud.
BenKus
January 17, 2009, 3:49am
3
You should check which folder the vbscript ends up in (which would depend on which folder it was in when it was packaged). It probably is in the __Download folder:
waithidden wscript /e:vbs __Download\replace.vbs …
system
January 19, 2009, 10:44pm
4
(imported comment written by FITZPAW91)
Thanks again, it seems to work
Now what I want to do is to create a value that is taken from a registry key (Computer Description) HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\lanmanserver\parameters\srvcomment and insert it into the extracted text file before the application runs. I have created a custom property for this, but I am unsure of how to use it.
I have a vbscript that allows me to use arguments e.g. replace.vbs arg1 arg2 textfile.
Help please.
William
system
January 20, 2009, 1:44am
5
Hi Fitzpaw,
So that other forum users can use it, could you precise what solved your problem and the syntax that finally worked?
To use the value of a registry key in your command line, write the relevance whitin curly brackets {}:
{value “srvcomment” of key “HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\lanmanserver\parameters” of registry}
According to your command line syntax, that will give something like:
replace.vbs arg1 {value “srvcomment” of key “HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\lanmanserver\parameters” of registry} textfile
Warning: if the value srvcomment doesn’t exist in the registry, the action will fail. You can add some checking before running the command line.
Arnaud
system
January 20, 2009, 10:20pm
6
Hi Arnaud
This is the syntax that worked,
waithidden wscript /e:vbs __Download\replace.vbs Nom_du_Serveur {Computer Name} __Download\Arcsight_SilentInstallation_Windows2003
run __Download\ArcSight-4.6.5.5120.0-Connector-Win.exe -i silent -f “C:\Program Files\BigFix Enterprise\BES Client__BESData\CustomSite_LQ_Home_Made__Download\Arcsight_SilentInstallation_Windows2003”
William
system
January 20, 2009, 10:28pm
7
Hi again,
Your syntax works as long as there are no spaces in the Computer Description. How should it look if there are spaces in the Computer Description…
William
system
January 20, 2009, 10:54pm
8
Hi Again again
All I needed was quotes around the curly brackets
replace.vbs arg1 “{value “srvcomment” of key “HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Services\lanmanserver\parameters” of registry}” textfile
Thanks for all the help
system
January 20, 2009, 11:13pm
9
Fitzpaw,
You’re right, you need quotes around the curly brackets.
Arnaud.
