Hello,
anyone familiare with exit code 24578?
Software Distribution action return this exit code with “Completed” status but crowdstrike does not appear installed.
I use last release of crowdstrike trying to install on Windows Server 2022.
Tks.
Hello,
Tks.
Sadly that exit code doesn’t come from BigFix but rather the installation itself
It looks like you’re encountering an issue related to the installation of the CrowdStrike Falcon Sensor. The exit code 24578 often indicates a problem with the installation process, which could be due to various reasons such as insufficient privileges, network connection issues, or missing certificates12.
Here are a few steps you can try to resolve this issue:
<installer_filename> /install /norestart CID=<your CID> ProvWaitTime=3600000
Replace <installer_filename> with the name of your installer file and <CID> with your Customer ID2.
