I have problems installing BigFix Remote control target on a terminal with OpenSuse Leap 15.5 when deploying with Bigfix it shows an error on the following line:
Completed parameter "FixletName" = "Deploy BigFix Remote Control Target for Linux"
Completed parameter "logFile" = "../rc_fixlet.log"
Completed if {exists parameter "paramRegToken"}
Completed parameter "runParamRegToken" = "{(parameter "paramRegToken" of action) as string}"
Completed else
Completed parameter "runParamRegToken" = ""
Completed endif
Completed if {exists parameter "paramManaged"}
Completed parameter "runParamManaged" = "{(parameter "paramManaged" of action) as string}"
Completed else
Completed parameter "runParamManaged" = "false"
Completed endif
Completed if {exists parameter "paramServerURL"}
Completed parameter "runParamServerURL" = "{(parameter "paramServerURL" of action) as string}"
Completed else
Completed parameter "runParamServerURL" = "false"
Completed endif
Completed wait /bin/sh -c "echo \"================================================================================================================================================================= \" >> {parameter "logFile"}"
Completed wait /bin/sh -c "echo \"INFO : Started Fixlet ({parameter "FixletName"}) at {now} \" >> {parameter "logFile"} 2>&1"
Completed prefetch trc_target_linux_10.0.0_0818.bfa sha1:c782ecd4c6fe523ddbaeb23bbbc3ccaeab8fd7d8 size:3546345 http://software.bigfix.com/download/TRC/trc_10.0.0/trc-10.0.0-0818/trc_target_linux_10.0.0_0818.bfa sha256:61cf3c3cbcc7ab74575f46e3ef269c38ba47b22998c0a50fdc740ddb26262913
Completed extract trc_target_linux_10.0.0_0818.bfa
Completed // The CLI conflicts with the Target so it needs to be removed first
Completed if {exists package ("trc-cli") of rpm}
Completed wait /bin/sh -c "echo \"INFO : Removing CLI Tools\" >> {parameter "logFile"} 2>&1"
Completed wait rpm -e trc-cli
Completed endif
Completed if {exists package ("ibm-trc-cli") of rpm}
Completed wait rpm -e ibm-trc-cli
Completed endif
Completed wait /bin/sh -c "echo \"INFO : Installing RPM - trc-target-10.0.0.i386.rpm \" >> {parameter "logFile"} 2>&1"
Completed wait rpm -U __Download/trc-target-10.0.0.i386.rpm
Completed parameter "ExitCode" = "{if exist exit code of action then exit code of action as string else "Not Set"}"
Completed if {parameter "ExitCode" = "0"}
Completed wait /bin/sh -c "echo \"INFO : Target was successfully installed. \" >> {parameter "logFile"} 2>&1"
Completed else
Completed wait /bin/sh -c "echo \"ERROR: Target was not properly installed. ExitCode={parameter "ExitCode"} \" >> {parameter "logFile"} 2>&1"
Failed exit {parameter "ExitCode"}
I would like to know how I can do it manually using bash or how I can resolve this error.
I deduce that it may be a permissions problem.
Can you help me please?
Thank you
