(imported topic written by bearandy)
I made a apk list to the android mobile.
I could see the recommended list for apk.
But I couldn’t download the file and install.
I direct copy the apk to the mobile and install it is OK.
What did I miss when I deploy the apk?
Thanks for help.
Hi bearandy,
What specific error did you hit when you tried to deploy your custom apk?
(imported comment written by bearandy)
When I Click install on device.
It show “Error: Download not available”.
Having the client logs would definitely help troubleshooting this issue.
If you could go to Troubleshooting -> Email logs and attach to this thread then we can have a closer look at the problem.
Also, can you check how much free space does the internal drive have? You can check this in Android Settings -> SD card and phone storage -> System storage (this is in Android 2.3, other versions might have it somewhere else).
