Dell has made detection of their model hard as they both are name the same in “Model from Win32_ComputerSystem” of wmi from the Computer model property we have.
Without changing the Model in WMIs Win32_ComputerSystem, or removing all the old PCs from our use, there’s not much that can be done to distinguish them apart by computer model alone is there?
You could try these in the Fixlet Debugger or an Analysis to see if there is some DMI way to distinguish the machines…
q: (manufacturer of it, product_name of it, version of it, sku_number of it, family of it) of system_informations of dmis
q: oem_strings of dmis
q: additional_informations of dmis
q: (product of it, version of it, feature_flags of it, board_type of it) of base_board_informations of dmis
I ran into this recently. Since the strings are the same, I stopped relying on the 'Model' property for these 'refresh' units. A quick way to split them in Relevance is to check the CPU generation. For the new 3550s, you can add a condition like: exists cpu whose (name of it contains "Ultra" or name of it contains "13th Gen") It’s much more reliable than waiting for Dell to fix their WMI strings. Once you have that, you can just AND it with the model name in your group criteria.
