Deletion of location by site code
Hi All,
Is it safe to just delete the “location by site code” analysis in manage properties? Thanks
Any comments please? I need to delete this analysis. I just want to make sure i will not break our server. Thanks
@washnware
I don’t think it will hurt anything, but I’d highly recommend exporting the property and/or analysis and then deactivating it for a period of time before fully deleting.
Hope this helps.
@cmcannady
@cmcannady
I can only find the analysis through manage properties so i am not sure if i can deactivate the analysis. Thanks
@washnware
As long as you have Master Operator access and have taken an export of the property, you should be OK as you can always add it back if necessary.
@cmcannady
