Below, please find the Ideas created in the Ideas Portal for the month of December 2021 for your reference. You can view their details, as well as vote or provide comments to those that interest you and your organization.
We will work to provide similar references here on the BigFix Forum in this Ideas category on a monthly basis for awareness and to foster additional collaboration.
Don’t have an account? It’s easy to sign up @ https://bigfix-ideas.hcltechsw.com/portal_users/new.
Thank you!
| URL | Idea name | Workspace name |
| https://bigfix-ideas.hcltechsw.com/ideas/BFCMPL-I-105 | Change the desired value on the compliance report | Compliance |
| https://bigfix-ideas.hcltechsw.com/ideas/BFCMPL-I-104 | Add Sorting Function and extra field to Exception Management | Compliance |
| https://bigfix-ideas.hcltechsw.com/ideas/BFCMPL-I-103 | SCM Checklist Request - DISA STIG for Oracle Linux 8 | Compliance |
| https://bigfix-ideas.hcltechsw.com/ideas/BFCMPL-I-101 | CIS Checklist for Apache Tomcat on Windows | Compliance |
| https://bigfix-ideas.hcltechsw.com/ideas/BFCMPL-I-100 | Ability for Compliance Analytics Administrators to view and manage all reports (including private reports) as well as any user-created object | Compliance |
| https://bigfix-ideas.hcltechsw.com/ideas/BFINV-I-247 | Possibility to disable the bundling assistant for specific components | Inventory |
| https://bigfix-ideas.hcltechsw.com/ideas/BFINV-I-246 | SQL AlwaysOn Availability Groups (AG) support for BFI Database | Inventory |
| https://bigfix-ideas.hcltechsw.com/ideas/BFINV-I-245 | Signatures for CrowdStrike Falcon Sensor for Unix systems | Inventory |
| https://bigfix-ideas.hcltechsw.com/ideas/BFINV-I-244 | Removing Part Numbers individually | Inventory |
| https://bigfix-ideas.hcltechsw.com/ideas/BFINV-I-243 | Report to identify Log4j 1.x with JMS Appender | Inventory |
| https://bigfix-ideas.hcltechsw.com/ideas/BFINV-I-242 | Progress bar on the audit snapshot state and Schedduling | Inventory |
| https://bigfix-ideas.hcltechsw.com/ideas/BFINV-I-241 | Enhance “Component Version” information to match with “Component Detailed Version” to track Fixpack changes for discovered Software Instances | Inventory |
| https://bigfix-ideas.hcltechsw.com/ideas/BFINV-I-240 | Acrobat DC 64bit と Acrobat Reader DC 64bit の判別 | Inventory |
| https://bigfix-ideas.hcltechsw.com/ideas/BFINV-I-239 | Product & metrics report - Remove rows (assigned metric from product ) | Inventory |
| https://bigfix-ideas.hcltechsw.com/ideas/BFLCM-I-137 | Extend VMWare Cloud Plugin Functionality - Ability to Power On/Off VMs | Lifecycle |
| https://bigfix-ideas.hcltechsw.com/ideas/BFLCM-I-136 | BigFix Remote Control - Add a Command Prompt Session Mode | Lifecycle |
| https://bigfix-ideas.hcltechsw.com/ideas/BFLCM-I-135 | Add stale content archival feature | Lifecycle |
| https://bigfix-ideas.hcltechsw.com/ideas/BFMCM-I-9 | Ability to use a system SSL certificate store with MongoDB for TLS configuration for the Plugin Portal for Mobile | Modern Client Management |
| https://bigfix-ideas.hcltechsw.com/ideas/BFMCLOUD-I-22 | VMware Cloud Plugin - Snapshot User Inspector | Multicloud |
| https://bigfix-ideas.hcltechsw.com/ideas/BFMCLOUD-I-21 | VMware Cloud Plugin - Snapshot Size Inspector | Multicloud |
| https://bigfix-ideas.hcltechsw.com/ideas/BFPTCH-I-212 | Add my reports to web reports | Patch |
| https://bigfix-ideas.hcltechsw.com/ideas/BFPTCH-I-211 | Collect/Download Bigfix Clients Logs to Bigfix Root Server/Console | Patch |
| https://bigfix-ideas.hcltechsw.com/ideas/BFPTCH-I-210 | Augment console columns | Patch |
| https://bigfix-ideas.hcltechsw.com/ideas/BFCMPL-I-102 | Add RHEL Pacemaker cluster as supported | Patch |
| https://bigfix-ideas.hcltechsw.com/ideas/BFPTCH-I-209 | Update Patch Support for Visual Studio to include 2017 and newer | Patch |
| https://bigfix-ideas.hcltechsw.com/ideas/BFPTCH-I-208 | Support BigFix Client and Patch Content on Amazon Linux 2022 | Patch |
| https://bigfix-ideas.hcltechsw.com/ideas/BFPTCH-I-207 | users need to see only role based actions (view/stop) not all actions displayed. | Patch |
| https://bigfix-ideas.hcltechsw.com/ideas/BFPTCH-I-206 | WebEx Meetings Desktop App Upgrade Fixlet - Ability to Patch regardless of whether or not Webex is running | Patch |
| https://bigfix-ideas.hcltechsw.com/ideas/IDEACNCTNS-I-2152 | 14 day scheduling in BigFix | Platform |
| https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-257 | Ability to double-click objects in the BigFix Console to open up that object in a different window | Platform |
| https://bigfix-ideas.hcltechsw.com/ideas/BFP-I-256 | Add additional Windows ‘processes’ inspectors like command line argument | Platform |
