Debug Menu not appear
Hello Bigfix
I’m not able to enable the Debug menu in my Cosole window even after pressing the Key " Alt+Ctrl+Shift+D" with master operator account
can any one help in this ? should i do any thing else ?
Hamed
Are you using a really old version of BigFix?
And are you using a remote desktop connection? (it should still work with remote desktop, but it might be somehow swallowing the keystrokes).
i’m using BigFix ver 7
and yes , i’m connecting to the Bigfix server using Remote desktop connection
do i have to check for something ?
Is it possible that someone disabled your debug menu? There is an advanced deployment option in BES Admin that can be entered to disable the debug menu…
Excellent !
you are right , i added myself this option one year ago and forgot about it !!
Thanks alot for your help
Hamed
