Thanks for the information. I will see if the half-ballon notification is useable. I don’t yet know how to go about sending a message which would be classified as a notification message, but I’ll have a look around.
( Btw, I’m glad the information is available, but perhaps the configuration settings page could be updated with the pieces from the kb page and the tasks?)
Secondly, I had forgotten to mention that the behaviour of the dashboard isn’t what I would expect (including the manual need to refresh the page). By this, I mean that if you minimise the dashboard and then either click on the icon in the taskbar, the dashboard opens but scrolls the page back to the top (annoying, as our technical page is somewhat lengthy). If you close the window and use ‘triggerclient.exe’ to bring it back up, the the window will reopen at the same spot on the page when it was closed. Odd.
The bigger issue is in the use of the technical page. In my mind the dashboard is for the user of the machine, whereas the technical one would be for a support person visiting (or RDPing/visiting) the desktop. When shift+ctr+alt+t is activated, the Technical page comes up, but this also means that
a) it becomes the default (open) page when you close and reopen the dashboard
b) the tab is always active in the dashboard until someone presses shift+ctrl+alt+t again.
This could be quite confusing for a user, when after a technician stops RDPing or walked away, a user will be faced with a non-standard situation.
http:// Yes, we know that technically, they should be able to cope, but in the real, business-world environment, we have to try provide a silver-spoon feeding service.
Could (should?) the dashboard tool be modified to remove the technical tab from the dashboard once it’s closed (toggle setting for it to false?) and to set the dashboard page to the default. If there are any users that want/need the current setting (which is to remain on the page that was last active when it was closed), perhaps that could be an additional configuration setting option.
I would think that when the dashboard is closed and reopened, it wouldn’t be too strange for anyone if it opened using the main, dashboard page. If they wanted to keep it on a single page, they could just minimise it and bring it up as needed.
Lastly, it may be that the lack of a ‘refresh on open’ was a technical limitation or it just happened to be coded that way, but it seems rather odd to me. I will now need to create a fixlet (or append to an action) that does addtional checks for whether we need to notify the user, add in a check that will read the time of the _currentdashboard.html file, if the interval is >x time, I will then do the “sc stop besclient & besclienthelper.exe & triggerclient.exe” to ensure the data that appears is relevant. Phew. This seems much too awkward. I should only have to send a message “There are one or more security issues with how your machine is configured. Please check the dashboard tool for more information.”, knowing that the dashboard tool is up to date, with all the smart relevance in _dashboard.html having created a nicely formated and informative _currentdashboard.html file.
I don’t want (nor do I think it should be necessary) to have to code in some javascript to continually update the page (which I think could be quite annoying) and I really don’t want to code in a redundant “Please click the refresh link” reminder text as the top of the page. I really just think that the dashboard when opened, reflects the current status, NOT the status from when it was last refreshed. This makes much more sense, unless I am missing all the PRO’s for why it was done the way it is now.
Please don’t think that I am knocking what I think is a very helpful tool. But due to the way it works, I’m just struggling to understand how to safely and easily integrate this tool into a very large user environment
Summary:
Investigate inconsistent behavior when opening the dashboard or bringing forward when minimised.
Technical page should close/disappear when dashboard is closed, with dashboard page set to default when opened/reopened. (shift+ctrl+alt+t toggle is reset to 0/false?)
Dashboard and Technical pages should be refreshed upon opening of dashboard. (Modifications to _dashboard.html will still require restarting client.)
