Hi Guys
I’ve installed the CPM, but due to different computergroups I need to customize an existing task:
Core Protection Module - Endpoint Deploy (Version 11 Service Pack 1)
This task can be found under Endpoint Protection → Deployment → Install.
I want to create a custom task called “Core Protection Module - Endpoint Deploy (Version 11 Service Pack 1) - Settings Only”, but when I do, I only have the option to create it in the Master Action Site (It’s a DEV environment, so no other custom sites). I would like to have that action also under Endpoint Protection → Deployment → Install.
Is this possible?
As always, thanks for your help!
