I am new to BigFix and I am struggling to create a custom report. I need to be able to report the following information to our Asset Management Department.
I have all the fields activated in the Console and they are reporting I just need to be able to get them into a report format and possibly even email it to the department. Any help would be greatly appreciated.
I might come back around to help you later with WebReports, but don’t want you to wait too long. Can you see if the following method will meet your needs?
Many screens in the BigFix Console can be copied, and paste nicely into Excel.
In the Computers tab, right click on the column names for the properties to organize them, or drag-and-drop to arrange them. You can then Ctrl-A to Select and copy to Excel.
This is often a very convenient way to get data from BigFix.
not sure I quite understand your question, but I think you’re asking how to use session relevance to inspect property results. There are 3 different query syntaxes, and each one can be useful in different situations, although they are often interchangeable:
values of results of
values of results from () of
values of results (, )
So if your property is named “Computer Model” and you want the values from all computers you could use any of these:
values of results of bes property whose (name of it = “Computer Model”)
values of results from (bes computers) of bes property whose (name of it =“Computer Model”)
values of results (bes computers, bes property whose (name of it = “Computer Model”))
