(imported topic written by PSanesi)
After a successful implementation of MDM based on iOS devices, now we’re considering the extension to Android devices.
One limitation I found is in the WiFi profiles configuration. Advanced, and more secure, configuration options of WiFi profiles seem to not be available via Dashboard.
In particular we’d like to configure WiFi as “WPA Enterprise” authenticated with personal certificate (as we already did with iOS).
On the Android side this is possible. But on the TEM side something seems missing.
In the “Android Actions” page of TEM Wiki the command string “set wifi profile ‘profile elements’” is documented, but which profile elements are available is not reported. If profile elements would be available we could create our own custom fixlet to configure WiFi profiles.
Is it this only a problem of documentation to be updated?
Will this features be added to WiFi Wizard?
The same considerations apply also to APN profiles that are documented on Wiki but not present ad Dashboard level
Thanks to anyone willing to share collected experiences in the matter above
Bye, Paolo
