I’m new to ILMT and I’m trying to install it for the first time. I have installed the Console and ILMT and now I have to create the SQL database. I’m using MS SQL Express 2014 as database. It is all installed on the same machine.
The problem is that I can’t create the database. I keep getting this error:
“Could not connect to xxxxx. Please check your connection information. and Invalid host and/or port value.”
I have tested all the ODBC connections and they all worked. I have tried to connect using the ip-address, serverhostname and localhost. I have even tried to use Firefox instead of IE, but it can’t connect.
I’m using Windows Authentication. It’s the same Windows admin user that is used to install all software and test the ODBC connections.
Hi!
Please check what account owns the ILMT process (Task Manager). By default it uses local SYSTEM account.
Check if that account has sufficient rights to create db on MSSQL side.
