(imported topic written by trdsmith91)
I am trying to replace text within an XML file on a workstation. Normally it is quite simple to append new data replacing the original data within the file. This time I am trying to replace the data within the XML file with a variable of whatever the hostname is on the workstation. My previous action script doesn’t work for this. Suggestions please?
Below is my text:
parameter “filename” = “C:\frustrating.xml”
appendfile {concatenation “%0d%0a” of (if (it contains " workstationid") then " {computer name}" else it as string) of lines of file (parameter “filename”)}
Any help would be greatly appreciated.
