(imported topic written by nberger91)
I need help concatenating the following expressions, product version is causing my brain to ache.
The format I need is -
SQL Server (ITDS) ||
10.0.4321.0
C:\Program Files\Microsoft SQL Server\MSSQL10.ITDS\MSSQL\Binn\sqlservr.exe
SQL Server (TEST) || 10.50.1804.0 || C:\Program Files\Microsoft SQL Server\MSSQL10_50.TEST\MSSQL\Binn\sqlservr.exe
q:
(display names
of
services
whose
(display name
of
it
as
lowercase
contains
“SQL Server”
as
lowercase
AND
display name
of
it
as
lowercase
does not contain
“Integration”
as
lowercase
AND
display name
of
it
as
lowercase
does not contain
“Analysis Services”
as
lowercase
AND
display name
of
it
as
lowercase
does not contain
“Reporting Services”
as
lowercase
AND
display name
of
it
as
lowercase
does not contain
“Server Agent”
as
lowercase
AND
display name
of
it
as
lowercase
does not contain
“VSS Writer”
as
lowercase
AND
display name
of
it
as
lowercase
does not contain
“Server Browser”
as
lowercase ))
A:
SQL Server (ITDS)
A:
SQL Server (TEST)
A:
SQL Server (VCDB)
A:
SQL Server (VCDB5)
T:
0.532 ms
q:
product versions
of
files(((
if
exists
substring between
“%22”
of
it
then
substring between
“%22”
of
it
else
it
of
image paths
of
services
whose
(display name
of
it
as
lowercase
contains
“SQL Server”
as
lowercase
AND
display name
of
it
as
lowercase
does not contain
“Integration”
as
lowercase
AND
display name
of
it
as
lowercase
does not contain
“Analysis Services”
as
lowercase
AND
display name
of
it
as
lowercase
does not contain
as
lowercase
AND
display name
of
it
as
lowercase
does not contain
“Server Agent”
as
lowercase
AND
display name
of
it
as
lowercase
does not contain
“VSS Writer”
as
lowercase
AND
display name
of
it
as
lowercase
does not contain
“Server Browser”
as
lowercase)))
A:
10.0.4321.0
A:
10.50.1804.0
A:
10.50.1804.0
A:
10.50.1790.0
T:
1.787 ms
q:
if
exists
substring between
“%22”
of
it
then
substring between
“%22”
of
it
else
it
of
image paths
of
services
whose
(display name
of
it
as
lowercase
contains
“SQL Server”
as
lowercase
AND
display name
of
it
as
lowercase
does not contain
“Integration”
as
lowercase
AND
display name
of
it
as
lowercase
does not contain
“Analysis Services”
as
lowercase
AND
display name
of
it
as
lowercase
does not contain
as
lowercase
AND
display name
of
it
as
lowercase
does not contain
“Server Agent”
as
lowercase
AND
display name
of
it
as
lowercase
does not contain
“VSS Writer”
as
lowercase
AND
display name
of
it
as
lowercase
does not contain
“Server Browser”
as
lowercase)))
A:
A:
A:
C:\Program Files\Microsoft SQL Server\MSSQL10_50.VCDB\MSSQL\Binn\sqlservr.exe
A:
D:\Data\VCDB5\MSSQL10_50.VCDB5\MSSQL\Binn\sqlservr.exe
T:
68.244 ms
