I used the repo dashboard to register some custom repos on a the master server (action completed successfully) and the client disappeared from the dashboard.
It still seems to be operating normally otherwise but now I can neither add another repo nor unregistered the existing ones.
Is this something anyone else has encountered and can comment on?
It’ll be some time before I get back to a deployment and check, but generally these dashboards use Analysis results as an input. Check that any related Analysis is still activated, and your clients are still subscribed to the site containing such Analysis (may be the Red Hat patching site, or may be the Patching Support site)
Thank you Jason. I see that the “Repository URLs” property is returning “<error>” now so that helps explain the issue. Not sure of the cause of the error so I will investigate and open a case if needed.
I was updating/configuring RHSM download plugin for multiple versions of RHEL OS and must have made an input or edit error somewhere. Removing all the .repo files and starting from scratch seems to have resolved the issue.
