(imported topic written by DC2308)
Hi All,
I would like to combine my customized Java 6.29 with the script Bigfix created that will close any running instance of IE, Firefox or Java but I’m not sure how to setup the script. Below I have my customized Java script and the one from the Bigfix. Basically, I would like to use the Bigfix script replacing with my customized Java MSI/MST so it closes any running instance of Java. Any ideas on how to set this up?
Thxs!
My Custom Java 6.29:
//**Begin Preparation Marker
// Download all specified files
begin prefetch block
add prefetch item name=B009005F82E5D89376E69A6FE766CA3F059A1F26 sha1=b009005f82e5d89376e69a6fe766ca3f059a1f26 size=13101952 url=SWDProtocol://127.0.0.1:52311/uploads/B009005F82E5D89376E69A6FE766CA3F059A1F26/Data1.cab.bfswd
add prefetch item name=C0A58FC61D9DAC0C113D56A9EAB9000BE108618F sha1=c0a58fc61d9dac0c113d56a9eab9000be108618f size=79488 url=SWDProtocol://127.0.0.1:52311/uploads/C0A58FC61D9DAC0C113D56A9EAB9000BE108618F/gtapi.dll.bfswd
add prefetch item name=7A3BBAAB20DE2FC996BCC1016E2379FE2B8B662F sha1=7a3bbaab20de2fc996bcc1016e2379fe2b8b662f size=15663616 url=SWDProtocol://127.0.0.1:52311/uploads/7A3BBAAB20DE2FC996BCC1016E2379FE2B8B662F/javacustom6v29.MST.bfswd
add prefetch item name=D4C4497137F9FB4A130AE940FFAD7FE1915A08AE sha1=d4c4497137f9fb4a130ae940ffad7fe1915a08ae size=907264 url=SWDProtocol://127.0.0.1:52311/uploads/D4C4497137F9FB4A130AE940FFAD7FE1915A08AE/jre1.6.0_29.msi.bfswd
add prefetch item name=6A8CF20F019266FFC125B93D2727A551877DE4A2 sha1=6a8cf20f019266ffc125b93d2727a551877de4a2 size=152576 url=SWDProtocol://127.0.0.1:52311/uploads/6A8CF20F019266FFC125B93D2727A551877DE4A2/lzma.dll.bfswd
end prefetch block
// All SWD Files will go into a folder in the clients __BESData folder. This folder get cleared on every restart.
parameter “baseFolder” = “__Download/”
// Move files into subfolders and unescape file names
move “__Download/B009005F82E5D89376E69A6FE766CA3F059A1F26” “{parameter “baseFolder”}Data1.cab”
move “__Download/C0A58FC61D9DAC0C113D56A9EAB9000BE108618F” “{parameter “baseFolder”}gtapi.dll”
move “__Download/7A3BBAAB20DE2FC996BCC1016E2379FE2B8B662F” “{parameter “baseFolder”}javacustom6v29.MST”
move “__Download/D4C4497137F9FB4A130AE940FFAD7FE1915A08AE” “{parameter “baseFolder”}jre1.6.0_29.msi”
move “__Download/6A8CF20F019266FFC125B93D2727A551877DE4A2” “{parameter “baseFolder”}lzma.dll”
//**End Preparation Marker
// Run setup process
delete __createfile
delete run.bat
// Use .bat to set working directory to packages root, for setup command.
createfile until
end
@ECHO OFF
cd “{parameter “baseFolder”}”
rem // See comments at the beginning of this action for an explanation of the comment markers.
rem //**Begin Command Marker
msiexec.exe /i “jre1.6.0_29.msi” /qn TRANSFORMS=“javacustom6v29.MST”
rem //**End Command Marker
end
move __createfile run.bat
// You will not be able to stop or take action on an applicable BES Client until your installer completes.
// So ensure no user input is required.
// If your package absolutely must interact with the user, replace ‘waithidden’ with ‘run’.
waithidden run.bat
BigFix Java 6.29 Script (will close any running instance of IE, Firefox or Java):
prefetch jre-6u29-windows-i586.exe sha1:a0f484c0521106b6fb5e75af3d6e4a6233a04f3a size:16897824 http://download.oracle.com/otn-pub/java/jdk/6u29-b11/jre-6u29-windows-i586.exe
// Note: update .exe will restart service automatically
if{exists running service “JavaQuickStarterService”}
delete __appendfile
delete stop_javaquickstarter.bat
appendfile net stop JavaQuickStarterService
move __appendfile stop_javaquickstarter.bat
waithidden stop_javaquickstarter.bat
endif
waithidden taskkill /F /IM java.exe
waithidden taskkill /F /IM javaw.exe
waithidden taskkill /F /IM javaws.exe
waithidden taskkill /F /IM iexplore.exe
waithidden taskkill /F /IM firefox.exe
regset "
HKEY_LOCAL_MACHINE\SOFTWARE\BigFix\EnterpriseClient\JavaInstallation
" “InstallingJava32”=dword:00000001
waithidden __Download/jre-6u29-windows-i586.exe /s /norestart
action may require restart “a0f484c0521106b6fb5e75af3d6e4a6233a04f3a”
continue if {((exists value “DisplayVersion” whose ((it >= “6.0.290”) of ((if (it as string = “1.5.0”) then (it as string & “.00”) else (it as string)) as version)) of keys whose ((value “DisplayName” of it as string as lowercase contains “j2se runtime environment” OR value “DisplayName” of it as string as lowercase starts with “java™”)) of it) AND (exists key whose (((it contains “java” OR it contains “j2se”) AND (it contains “runtime environment” OR it contains “update”)) of (value “DisplayName” of it as string as lowercase)) of it)) of key “HKLM\Software\Microsoft\Windows\CurrentVersion\Uninstall” of registry}
regdelete "
