(imported topic written by murtasma91)
I’m trying to direct certian clients to use a particular relay using the manual relay selection. When I send the action out to change from automatic to manual and specfic the Primary and Secondary relay the workstations will not registry with the primary or secondary relay. Instead they randomly select one of our other available relays. Once I deploy this setting to the client I even tried runing the following script without sucess.
relay select
notify client forceRefresh
The clients would still communicate with a relay that was not part a primary or secondary. When I view the action results for the action that sets the relay configuration options I see the following which looks correct.
Completed setting “__RelaySelect_Automatic”=“0” on “Fri, 01 Jul 2011 20:08:28 +0000” for client
Completed setting “__RelayServer1”=“http%3a%2f%2fumd-caslrelay%2eadsroot%2eitcs%2eumich%2eedu%3a52311%2fbfmirror%2fdownloads%2f” on “Fri, 01 Jul 2011 20:08:28 +0000” for client
Completed setting “__RelayServer2”=“http%3a%2f%2fBFIT-CPPMTS03%2eadsroot%2eitcs%2eumich%2eedu%3a52311%2fbfmirror%2fdownloads%2f” on “Fri, 01 Jul 2011 20:08:28 +0000” for client
If I change the settings twice they seem to stick properly. These log snipets are from the same client.
1st time I attempted to set relay manually.
At 17:37:55 -0400 - actionsite (http://cppmservice.umich.edu:52311/cgi-bin/bfgather.exe/actionsite)
Relevant - Change Multiple Settings (fixlet:109975)
BackgroundAdviceEvaluation NonTargetedFile optimization of C:\Program Files\BigFix Enterprise\BES Client__BESData\actionsite\Action 109971.fxf
At 17:37:55 -0400 -
ActionLogMessage: (action 109975 ) Action signature verified
ActionLogMessage: (action 109975 ) starting action
At 17:37:56 -0400 - actionsite (http://cppmservice.umich.edu:52311/cgi-bin/bfgather.exe/actionsite)
Command succeeded setting “__RelaySelect_Automatic”=“0” on “Fri, 01 Jul 2011 20:08:28 +0000” for client (fixlet 109975)
Command succeeded setting “__RelayServer1”=“http%3a%2f%2fumd-caslrelay%2eadsroot%2eitcs%2eumich%2eedu%3a52311%2fbfmirror%2fdownloads%2f” on “Fri, 01 Jul 2011 20:08:28 +0000” for client (fixlet 109975)
Command succeeded setting “__RelayServer2”=“http%3a%2f%2fBFIT-CPPMTS03%2eadsroot%2eitcs%2eumich%2eedu%3a52311%2fbfmirror%2fdownloads%2f” on “Fri, 01 Jul 2011 20:08:28 +0000” for client (fixlet 109975)
At 17:37:56 -0400 -
ActionLogMessage: (action 109975 ) ending action
Not Relevant - Change Multiple Settings (fixlet:109975)
At 17:38:18 -0400 -
Report posted successfully.
At 17:38:20 -0400 -
RegisterOnce: Attempting to register with ‘http://BFIT-CPPMREL03.adsroot.itcs.umich.edu:52311/cgi-bin/bfenterprise/clientregister.exe?RequestType=RegisterMe60&ClientVersion=8.0.627.0&Body=608975&SequenceNumber=162&MinRelayVersion=6.0.0.0&CanHandleMVPings=1&Root=http://cppmservice.umich.edu%3A52311&AdapterInfo=00-23-ae-98-88-96_141.215.162.0%2F23_141.215.163.170_1’
Unrestricted mode
Configuring listener as wake-on-lan forwarder(AdapterInfo=00-23-ae-98-88-96_141.215.162.0/23_141.215.163.170_1).
Registered
2nd time which stuck
At 11:09:25 -0400 - actionsite (http://cppmservice.umich.edu:52311/cgi-bin/bfgather.exe/actionsite)
Relevant - Change Multiple Settings (fixlet:110142)
At 11:09:25 -0400 -
ActionLogMessage: (action 110142 ) Action signature verified
ActionLogMessage: (action 110142 ) starting action
Command succeeded setting “__RelayServer1”=“http%3a%2f%2fumd-caslrelay%2eadsroot%2eitcs%2eumich%2eedu%3a52311%2fbfmirror%2fdownloads%2f” on “Tue, 05 Jul 2011 14:29:13 +0000” for client (fixlet 110142)
Command succeeded setting “__RelayServer2”=“http%3a%2f%2fBFIT-CPPMTS03%2eadsroot%2eitcs%2eumich%2eedu%3a52311%2fbfmirror%2fdownloads%2f” on “Tue, 05 Jul 2011 14:29:13 +0000” for client (fixlet 110142)
At 11:09:25 -0400 -
ActionLogMessage: (action 110142 ) ending action
Not Relevant - Change Multiple Settings (fixlet:110142)
At 11:09:57 -0400 -
At 11:09:58 -0400 -
RegisterOnce: Attempting to register with ‘http://umd-caslrelay.adsroot.itcs.umich.edu:52311/cgi-bin/bfenterprise/clientregister.exe?RequestType=RegisterMe60&ClientVersion=8.0.627.0&Body=608975&SequenceNumber=168&MinRelayVersion=6.0.0.0&CanHandleMVPings=1&Root=http://cppmservice.umich.edu%3A52311&AdapterInfo=00-23-ae-98-88-96_141.215.162.0%2F23_141.215.163.170_1’
Unrestricted mode
Registered
