Client Settings - Relevance Expression
Hello,
I want to setup a relevance to change these values if one or more of them are false. I have the action working just fine and each of these runs correctly on their own, but run as a whole it does not work correctly.
I have tested other ways and contacted our tech rep but cant seem to get this to work.
Thanks in advance…
exists setting “__RelaySelect_Automatic” whose (value of it = “0”) of client OR
exists setting “_BESClient_Register_Affiliation_SeekList” whose (value of it = “PAS”) of client OR
exists setting “_BESClient_Download_LimitBytesPerSecond” whose (value of it = “100000”) of client OR
exists setting “_BESClient_Download_PreCacheStageDiskLimitMB” whose (value of it = “1000”) of client OR
exists setting “_BESClient_Inspector_DisableWMI” whose (value of it = “1”) of client
2nd try
((if exists setting “__RelaySelect_Automatic” of client then (value of setting “__RelaySelect_Automatic” of it != “0”) of client else false) OR
(if exists setting “_BESClient_Register_Affiliation_SeekList” of client then (value of setting “_BESClient_Register_Affiliation_SeekList” of it != “RETAIL”) of client else false) OR
(if exists setting “_BESClient_Download_LimitBytesPerSecond” of client then (value of setting “_BESClient_Download_LimitBytesPerSecond” of it != “100000”) of client else false) OR
(if exists setting “_BESClient_Download_PreCacheStageDiskLimitMB” of client then (value of setting “_BESClient_Download_PreCacheStageDiskLimitMB” of it != “1000”) of client else false) OR
(if exists setting “_BESClient_Inspector_DisableWMI” of client then (value of setting “_BESClient_Inspector_DisableWMI” of it != “0”) of client else false))
I have a similar fixlet, try this out:
(exists values whose (it as integer = 0) of settings "__RelaySelect_Automatic" of client) or (exists values whose (it = "PAS") of settings "_BESClient_Register_Affiliation_SeekList" of client) or (exists values whose (it as integer = 100000) of settings "_BESClient_Download_LimitBytesPerSecond" of client) or (exists values whose (it as integer = 1000) of settings "_BESClient_Download_PreCacheStageDiskLimitMB" of client) or (exists values whose (it as integer = 1) of settings "_BESClient_Inspector_DisableWMI" of client)
Also, when posting code on the forum be sure to use the “preformatted text” button, otherwise certain characters like underscores tend to get eaten.
@UnknownSample
Likely what is happening with your Relevance is that you are checking the Value of a setting that doesn’t exist and getting an Error. You can see that with the code @Sean provided, he is checking to see if the Value exists before comparing the Value of it.
Just for grins and giggles, Client Settings can exist without a Value existing for them. This happens when you delete a Setting. The Setting itself is not deleted, but the Value is, so you can end up with the following …
Exists Setting "AB" whose (not exists Value of it)
I’d write it something like …
(exists setting "_RelaySelectAutomatic" whose (Exists Value of it AND value of it = "0") of client) OR (exists setting "BESClientRegister_Affiliation_SeekList" whose (Exists Value of it AND value of it = "PAS") of client) OR (exists setting "BESClientDownload_LimitBytesPerSecond" whose (Exists Value of it AND value of it = "100000") of client) OR (exists setting "BESClientDownload_PreCacheStageDiskLimitMB" whose (Exists Value of it AND value of it = "1000") of client) OR (exists setting "BESClientInspector_DisableWMI" whose (Exists Value of it AND value of it = "1") of client)
as with skinning cats, there are a lot of ways to write Relevance!
