Hello,
May I know what the client setting _BESClient_Inspector_RPMDisableHelper is for?
We are experiencing issue installing the “Install or Upgrade Scanner” from BFI site and saw a PMR saying that this value needs to be set to the value of 1 in order to solve the Relevance substitution error.
At 11:00:16 -0500 - mailboxsite (http://bfxserver:52311/cgi-bin/bfgather.exe/mailboxsite559837)
Relevant - Install or Upgrade Scanner (fixlet:8171)
At 11:00:22 -0500 -
ActionLogMessage: (action:8171) Action signature verified for Downloads
ActionLogMessage: (action:8171) Relevance substitution error.
At 11:00:24 -0500 -
ActionLogMessage: (action:8171) ending action
At 11:00:27 -0500 - mailboxsite (http://bfxserver:52311/cgi-bin/bfgather.exe/mailboxsite559837)
Not Relevant - Install or Upgrade Scanner (fixlet:8171)
At 11:00:41 -0500 -
Report posted successfully
The technote http://www-01.ibm.com/support/docview.wss?uid=swg21638794 suggest that setting the value to 1 will disable the RPM helper from running. Why do some machines was not able to experience the relevance substitution error? Does this mean that by default, the RPM helper is not supposed to be running?
Thank you.
