I have clients in my console that show for the “Computer Name” (and some of the other columns), but “Last Report Time” is current. The odd thing is, when I double-click these, they show the details (including computer name) in the bottom pane and then no longer show as in the top pane. Any ideas?
My console was set to “Keep full cache on disk” (Moderate). I changed it to “Keep partial cache on disk (fast net and fast disk)” and did a “Clear Cache”. It has been a couple of days now and those have not shown back up. So, it appears that has taken care of it. Thanks.
I have the same problem and my settings are already set to keep partial cache on disk, and I have already cleared cache. I moved on thinking the problem had to be on the client, so far the only fix I find for this is completely removing the BES Client using the utility and reinstalling it. There’s got to be a better way!
PS. I also tried deleting the revocations file and restarting the service.
I did it by computer ID, and I still have the under status. We are running a frame relay network with NATd ip addresses, do you think it has something to do with it?
