(imported topic written by Rominal91)
How would you send a link or URL to users and have them install the client by clicking the link?
Hello Rominal,
I have seen customers using the WinZip Self Extractor to provide the ability to click on a link and kick off the entire installation process.
http://www.winzip.com/prodpagese.htm
Lee Wei
(imported comment written by Rominal91)
Thanks, My hope was to just email a link or URL that would then install the client. I did not want to email 600 users a zip package.
I’m also looking at creating a self-extracting .exe file for the client installation for some remote users. Is there a way to make the setup.exe slient? E.g. pass it parameters?
I believe setup /s is the switch to make the installer go silent.
I have used WinZip Self Extractor to create the self-extracting file for easy download/install via web pages.
Thanks Lee Wei. I ended up using a -s and that appears to work as well. I’m using WinRAR to create a self extracting exe.
