CIS Checklist CentOS 6 Accidently Removed
Dear all
can any one help on this I have accidently removed CIS Checklist for Linux CENTOS 6 from External site, how can i recover it
pls help
In the BES Console, switch to the ‘BigFix Management’ Domain, then use the ‘License Overview’ dashboard to find and enable the ‘CIS Checklist for RHEL 6’ Site.
You may also need to re-subscribe your computers and reassign operator rights to match how you were using it previously.
Sir
Tank you so much, i just need your opinion, If i am not using any CIS Checklist for any kind of Operating system is it a good practice to remove them from external site.???
Yes, it would be best to remove any Checklist that you’re not using. The Console has to spend time loading and caching this content; if you’re not using it, there’s no need.
It’s simple enough to add it back again later if you do need it.
Dear sir
Appreciate your advise,
just to ask you one more time, i am extracting report from Bigfix Compliace platform, but what i see is its a plain report there is no HCL or Bigfix header like there is in manageengine, is there is a way to enable something like that, because i have to present report to my bosses, pls help kindly
