CIDSETTINGNAME and CIDSETTINGVALUE
(imported topic written by JasonBigham91)
We use these to identify different client sites for grouping inside the console.
In the 7.x MSI, we could add these to the MSI so we could deply and not have to manually apply a CID so they would group properly. This does not seem to work in the 8.x MSI; seems to ignore these. Anybody know if these names have changed and what they might be?
Using Orca:
Open MSI, go to PROPERTY section, add the rows with corresponding PROPERTY and VALUE.
Screenshots attached to assist showing a 7.x MSI which works just fine and a 8.x MSI which works in every regard but the CID assignment.
(imported comment written by JasonBigham91)
Not working
This is where it ends up on a 64bit machine (after manually applying it via the console)
HKEY_LOCAL_MACHINE\SOFTWARE\Wow6432Node\BigFix\EnterpriseClient\Settings\Client\cid
STRING
data: O2152
Anyone know?
