so the way this works is, you put the first part into a fixlet, this outputs the CTX details to a file.
you send this out to the target machines.
then build an analysis to read back the contents of the file.
analysis property 1
lines of file “C:\temp\PythonCTX.txt”
analysis property 2
(pathname of it, creation time of it, modification time of it, size of it, sha1 of it) of files ((it as trimmed string & “\ctx.py”) of (following texts of firsts “Location:” of lines of file (“C:\temp\PythonCTX.txt”)))
