I have this ActionScript in a custom action… it’s failing. I’ve tried all sorts of syntax but I am drawing blanks…(old age syndrome…)
if {member of group 1075264 of sites “Data Center”} setting “groupClassID”=“1” on “{now}” for client endif exit 0
If it’s a custom site, I suspect its correct name should be CustomSite_Data_Center. You can use FixletDebugger to test your relevance.
Fixlet IDs must be unique among all custom sites in a deployment, so member of group 1075264 of sites should work (i.e. no need to reference the specific custom site)
