(imported topic written by nrupaks91)
Dear All,
I would like to change $ to INR in Override Power Assumptions.
Please suggest how to proceed.
Regards,
Nrupak D. Shah
Dear All,
Regards,
Nrupak D. Shah
Hey Nrupak,
Although the Power Assumptions Override Wizard displays the ‘$’ for power cost, it does not store any currency unit, just the value. This means the value you input can be interpreted as dollars, INR, or any other unit, without affecting the actual calculations in the power management dashboard.
The power management dashboard lets you select the monetary symbol you wish to display in your power calculations, however it does not currently offer INR as a value. I have filed a request for this.
-Zak
(imported comment written by nrupaks91)
Hi Zak,
Thanks very much for the same.
Regards,
Nrupak D. Shah
