The normal BigFix services work just fine with (g)MSA accounts. When installing WebUI the installer will not work if you do not supply a password with the user name. Leaving it blank says bad password.
When using the fixlet Deploy/Update WebUI Database Configuration if you leave the password blank you get an error the password cannot be left blank.
MSA accounts do not contain a password.
