Hello All,
I am new to this forum but have used it in the past for countless customization’s that has helped me effectively manage my BigFix deployment for the past 8 years.
I am now looking for some help on how to bulk schedule automation plan jobs either via SQL queries, API, or GUI Console.
My objective is to schedule ~100 automation plans at the same time with the same exact scheduling options.
Same start date/time and same end date/time
Same prefetch start time/date
Each plan already has machines statically assigned so we just need the automation or bulk option for the scheduling.
It’s incredibly tedious and takes a very long time to run through over 100 automation plans. I assume since each Automation Plan has a unique non–changing ID it would be possible to cut and paste all 100 plan ID’s into a SQL query or REST API with the same parameters to schedule.
I just can’t find anywhere in the REST API where this is accomplished.
Any help would be greatly appreciated before reaching out to BigFix Professional Services.
Thank You,
Andrew
