BigFix WebUI dashboard editing issue
Hi Everyone,
I am having some strange behavior of BigFix WebUI in our environment.
We have installed a webui on a windows 2012 server and it was working fine and able to see the tiles on overview page.
But when I edited some tiles, my overview page is stuck into loading from past more than 24 hrs and even ‘Edit Dashboard’ panel is missing, you can see in attached snap.
I have already tried to remove it(deleted folders also) and reinstall it, but no luck. Even tried to install on another system but facing the same issue.
Rest of the pages and tabs are working perfectly fine. Only having issue with overview page.
Any suggestions?
Is this in a DSA Environment?
What platform version are you running? Have you upgraded the platform since you installed the WebUI service?
Any more specific errors would be logged (for Windows) in the following:
(On the WebUI server): …/WebUI/logs/common.log
(On the BES Server): …/BigFix Enterprise/BES Server/BESRelay.log
Hi @jeremylam,
We are using BigFix 9.5.5 and installed the same version of WebUI on different host.
I am attaching the logs you mentioned.
Common.log
Wed, 07 Jun 2017 05:43:33 GMT bf:bfapp:debug Common 0.3.0 listening on port 5003 in production mode
BESRelay.log
Wed, 07 Jun 2017 23:55:22 +0530 - /cgi-bin/bfenterprise/besgathermirror.exe/-siteversion (3728) - Unable to find site id for URL: http://sync.bigfix.com/cgi-bin/bfgather/virtualendpointmanager
Thu, 08 Jun 2017 10:55:55 +0530 - /cgi-bin/bfenterprise/besgathermirror.exe/-siteversion (3680) - Unable to find site id for URL: http://sync.bigfix.com/cgi-bin/bfgather/avclient
Thu, 08 Jun 2017 10:55:55 +0530 - /cgi-bin/bfenterprise/besgathermirror.exe/-siteversion (3392) - Unable to find site id for URL: http://sync.bigfix.com/cgi-bin/bfgather/bigfixlabs
Thu, 08 Jun 2017 10:55:55 +0530 - /cgi-bin/bfenterprise/besgathermirror.exe/-siteversion (2208) - Unable to find site id for URL: http://sync.bigfix.com/cgi-bin/bfgather/maas360mobiledevicemanagement
Thu, 08 Jun 2017 10:55:55 +0530 - /cgi-bin/bfenterprise/besgathermirror.exe/-siteversion (4796) - Unable to find site id for URL: http://sync.bigfix.com/cgi-bin/bfgather/powermanagement
Thu, 08 Jun 2017 10:55:55 +0530 - /cgi-bin/bfenterprise/besgathermirror.exe/-siteversion (3996) - Unable to find site id for URL: http://sync.bigfix.com/cgi-bin/bfgather/tivoliremotecontrol
Thu, 08 Jun 2017 10:55:55 +0530 - /cgi-bin/bfenterprise/besgathermirror.exe/-siteversion (4732) - Unable to find site id for URL: http://sync.bigfix.com/cgi-bin/bfgather/trendcpm
Thu, 08 Jun 2017 10:55:55 +0530 - /cgi-bin/bfenterprise/besgathermirror.exe/-siteversion (3432) - Unable to find site id for URL: http://sync.bigfix.com/cgi-bin/bfgather/trendreporting
Thu, 08 Jun 2017 10:55:55 +0530 - /cgi-bin/bfenterprise/besgathermirror.exe/-siteversion (3580) - Unable to find site id for URL: http://sync.bigfix.com/cgi-bin/bfgather/virtualendpointmanager
Regard,
Manoj Thathera
Hi ,
Can I have any update on this?
@jeremylam
@leewei
@jgstew
@Aram
That is interesting that the issue is so specific to the overview page.
You will likely have to file a PMR to get this resolved: How to ask for product help: PMRs, RFEs, and more
There may be a way to reset the overview to fix this, but I’m not sure how to go about that.
