Hi
My Web reporter does not have the Import report feature β how / where do i enable it?
Hi
Hi
Normally this should be there by default:
What version are you using?
Hi i am using 9.5.2.56
on web reporter there is a tab there
Hi, in new installs of 9.5, the ability to import custom reports is disabled by default. It can be re-enabled setting a value of 1 for the registry setting HKLM\Software\WOW6432Node\BigFix\Enterprise Server\BESReports\AllowCustomReportCreation.
Here are more details: http://www.ibm.com/support/knowledgecenter/SS6MCG_9.5.0/com.ibm.bigfix.doc/Platform/Web_Reports/c_creating_a_custom_report.html
And in case itβs useful, there is a screenshot in a related discussion here: Bigfix 9.5 import Custom Webreports option not coming
@joseg You are a Life Saver!!
Thank you Sir !!!
