I see, thank you.
As you note above, the current version’s design is to map data directly into the cmdb_ci_computer table, though we are exploring expanding that to support other tables and data synchronization mechanisms with our ServiceNow Data Flow integration. However, being a roadmap item, it’s timeframe is of course subject to change (we do not have a committed timeframe at the moment, but will update here when we do have a better timeframe to share).
That said, I’m not sure if you’ve seen our Service Graph Connector for BigFix that may help here depending on your requirements and entitlements (i.e. requires BigFix Inventory). Sharing here just in case as it does support data mapped to multiple tables today, as well as the use of import sets.
