Planning to use BigFix ServiceNow Data Flow for getting data from the BigFix server.
So is there any plugin that is to be installed in the ServiceNow instance for doing this?
Please help finding a solution.
Thank you.
Thank you.
The short answer is no. This particular integration leverages ServiceNow platform APIs. Please see https://help.hcltechsw.com/bigfix/10.0/integrations/Ecosystem/Install_Config/c_concepts.html for more details.
