In BigFix ServiceNow Data Flow method, we bring data to cmdb_ci_computer table.
Need to know what attributes will be populated in this integration method.
Kindly help with a solution.
Thank you
Thank you
It’s whatever you have configured to in the DataFlows.config file - there are SNow-to-BigFix adapter and BigFix-to-SNow adapter section and in each there are set of patching fields (essentially, they are which property from the source adapter to get the data and which property in the target adapter to write the data to), so you can have it read from any BF property and write to any ServiceNow property (and vice-versa).
